Ken's Sonex 1243
Re: Ken's Sonex 1243
Postby Sonex1243 » Sun Nov 22, 2015 11:13 pm
Spent some time away from the Sonex while doing the annual on our beech sierra. Since the Sierra was almost done, I got a quick Sonex fix today by modding the left O/B wing ribs for the duckworks LED light. Also cleco'd the rear spar in place, the wing is ready for up sizing to #30.
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Sun Dec 20, 2015 11:38 pm
Wing has been upsized. Since then, everything has been finally deburred, edge finished and cleaned up. I also went over the main spar again to clean it up and remove some dings from all the handling. Will start riveting the ribs and rear spar soon.
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Thu Dec 24, 2015 9:33 pm
Happy holidays everyone. Maybe the elves will visit tonight and tomorrow morning the skins will be on?
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Sun Dec 27, 2015 11:51 pm
A mysterious elf showed up over the weekend. Upper and lower skins fit, starting the forward skin.
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Bryan Cotton » Mon Dec 28, 2015 1:48 am
Looks good Ken. If your mysterious elf does fiberglass please send him my way. I hate the stuff!
Postby Sonex1243 » Mon Dec 28, 2015 9:10 pm
Thanks Bryan;
I am not looking forward to my turn with that stuff. I made a feeble attempt at the right wing tip and got frustrated pretty quick after notching and trimming. I tried to fit it with the aft tip flange on and induced a few broken chips, only after researching the Sonex site I found the wing tip instructions telling you to remove the flange..
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Fri Jan 01, 2016 10:13 pm
Leading edge in work, upper side pilot drilled, flipped it over and started the lower side.
After much delay, I finally bit the bullet and fabricated a support stand. I got the idea from Carl Ortons build site, who also encountered the wing constantly slipping off the support blocks. I kept the angles and heights exactly the same and the wing fits real nice in the cradle. Why didn't I do this with the right wing?? Thanks for the help and idea Carl.
I should be farther along, but, went flying and did some approaches for instrument currency today, beautiful weather today (unusual for ND) to do it.
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Wed Jan 06, 2016 11:55 pm
Finished up sizing the rest of the wing skins and doubler to #30. Drilled the forward skin and ribs to #32 for dimpling.
Dis-assembly in work
Cleaned up the shop, ready for deburring
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Bryan Cotton » Thu Jan 07, 2016 8:11 am
Boy are we neck and neck or what.
Postby Sonex1243 » Thu Jan 07, 2016 7:52 pm
I guess so Bryan! I think you have the upper hand with extra deburring / polishing power. The skins should go quick like the right wing, then polish and dimple as needed. The wing box seems to take a little more time, mostly the main spar for me. Your second wing will go much faster, like mine.
We are expecting some sub zero temps starting tomorrow afternoon through the weekend and into next week, a real buzz kill for working in the garage!
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Return to Photo Album
Users browsing this forum: Google [Bot] and 5 guests
