bakfly wrote:Have anybody looked into the D-MOTOR LF 26 as an alternative for the aerovee engine.
The D-Motor is almost 50lb (24kg) lighter, produce 92hp at 3000rpm and almost 89hp at 2800rpm. It is Liquid Cooled can run on 95 octane or Avgas and fit on an Jabiru engine mount.
My nose-wheel Sonex is a bit nose heavy and a bit less weight on the nose would help and I can carry more load.
Cost almost AU$21000.
Peter Bakker,
Sonex 1430 Aerovee 2.1
Done 86hrs.
I'm slightly confused by your post. Did you mean that, with a 60-inch prop, you had 3 inches less prop-ground clearance than Steve with his 57-inch prop? I would think that would give you 1.5 inches less clearance. Did standard tires reduce the prop-ground clearance another 1.5 inches (versus Steve's 5:00 X 5 tires)?
Sonex 32 wrote:Just for what it's worth, an LSA is restricted to 10,000 ft. MSL.
I am flying old #32, Tony Spicers Sonex with a Jabiru 3300 with 740 hrs. I climb to 8500 from my field elevation of 1100 on average of 6-8 mins using a climb speed off 120-130 mph. Ya gotta love it. Only burn on average 5 gph.
There are Jabiru 3300 out there for sale and after flying mine for over 5 years, I must say I love it!
Bob B
Sonex 032
Users browsing this forum: No registered users and 36 guests
