heat treat stainless exhaust?
Postby marvdavidson » Thu Dec 24, 2015 10:13 am
is heat treating the stainless exhaust recomended? please advise.
Marv
aerovee arrived yesterday. wahoo!!!!!!!!
marvdavidson
Re: heat treat stainless exhaust?
Postby Bryan Cotton » Thu Dec 24, 2015 11:48 am
Marv,
Do you mean heat treating where you stick the parts in an oven up around 1000C? I don't think there is much need for that. If you mean coating or wrapping the exhaust, that I plan to do. I will probably wrap mine. It is good to keep the heat out of the engine bay.
Congrats on the new Aerovee!
Postby marvdavidson » Thu Dec 24, 2015 10:04 pm
Hi Bryan,
I was thinking more along the lines of sending the exhaust to a place in N. carolina for ceramic coating, around 275 with a lifetime guarantee...... sounds better than the wraping......any experience with either?
marvdavidson
Postby kmacht » Thu Dec 24, 2015 10:16 pm
I have mine wrapped. 70 hours and no sign of any issues under the wrap after pulling it off for the annual. It does seem to have a big influence on under cowl temperatures. If it is really needed I don't know. I just added it because it was inexpensive and figured it couldn't hurt especially with the gas line running a few inches away. Not sure I would spend $275 to have it coated though.
Postby jjbardell » Fri Dec 25, 2015 8:28 am
I was thinking of coating and wrapping mine as well but decided to how its the wrap alone. My concern around doing both is the exhaust could get to too hot if you do both. I have read it is best to do one or the other. And that's why I went with wrap...it came with the exhaust.
N83LJ - Sonex #0864 (SOLD)
jjbardell
Postby mike.smith » Fri Dec 25, 2015 11:28 am
kmacht wrote:I have mine wrapped. 70 hours and no sign of any issues under the wrap after pulling it off for the annual. It does seem to have a big influence on under cowl temperatures. If it is really needed I don't know. I just added it because it was inexpensive and figured it couldn't hurt especially
Likewise for me, at 140 hours. No degradation of the exhaust at all (which is one of the arguments against wrapping). Definitely keeps the temps down under the cowl.
Postby Sonex1462 » Fri Dec 25, 2015 1:03 pm
I had mine ceramic coated by a local company here in Phoenix. They did both inside and out for $225. I have only test started my aerovee a couple of times so I don't have any experience to share yet. Other local people have had good results on other engines with them.
John Stewart
Sonex 1462
Sonex1462
Postby billmaxmcw » Sat Dec 26, 2015 4:16 pm
I had mine ceramic heat-treated (with the exhaust manifold), but after some bad burps I wrapped it also (along with rerouting and insulating the fuel line). No problems since. No evidence of complications doing both.
Bill
Bill, Oregon
2012 Sonex taildragger (kit)
Aerovee 2.1, Aeroinjector
billmaxmcw
Users browsing this forum: No registered users and 82 guests
