Bryan Cotton wrote:Hi all,
I bought some 1/4" OD poly tubing at Lowes Depot, <$4 for 25'. It fits right into the tooling holes in the ribs and would hold either a twisted pair (LED landing lights) or twisted triple (LED nav and strobe) 20 or 22 gauge wire. In Mike's picture above, he mounted his gaugepods forward of the spar. At the gaugepods site, they mount behind the spar. Any thoughts if one is better than the other? If I mount behind the spar, I would use the forward tooling hole in the aft rib for the nav/strobe lights. For the landing lights, I would run a tube/wire in the aft hole of the forward ribs.
For landing lights I have the fresh aero units with the Sonex installation kit. In their pictures it shows the nav light forward of the spar. I bought these from Dennis on the Sonexbuilders classifieds. They seem like really nice and reasonably priced units.
http://www.freshaero.com/tlrlight.html
For nav light mounts I have the gaugepod units.
Picture from their site:
If I can't get confirmation that I will get approval to fly at night with non-TSO lights I will probably buy Whelen Orion 650's:
http://www.aircraftspruce.com/pages/el/ ... series.php
Any thoughts on this plan?
Sonex1243 wrote:Any thoughts if one is better than the other? If I mount behind the spar, I would use the forward tooling hole in the aft rib for the nav/strobe lights. For the landing lights, I would run a tube/wire in the aft hole of the forward ribs.
I had seen some comments to use the forward rib holes, only because using the aft rib holes puts your wiring run on the same side with the flap and aileron control pass through the fuselage making it difficult / troublesome to disconnect everything when / if you ever remove your wings. my quick .02c.
Bryan Cotton wrote:All,
I am thinking of leaving the strobes on all the time - no switch, just a breaker. The thought would be an aid to remember the master switch. Any issues drawing 2A on the ground for strobes when alternator output is low?
Users browsing this forum: No registered users and 20 guests
