So I fabricated a special tool to remove the oil pressure relief plungers, very simple:
Just a section of 1/2 aluminum tubing with one end slightly ovaled so that it's a tight fit into the hollow plunger. The mark shows the normal insertion depth, and the tool can also double as a holder to polish the plunger using a 3M polishing wheel. Which is what I did until the plunger slid in and out easily for all rotational angles.
However, after satisfying myself that the plunger wasn't sticking, on re-start, I'm still seeing over 100 psi, as verified by multiple gauges, both analog as well as digital. I have no oil cooler, and have connected the in and out ports of the oil pump, as suggested in the assembly manual. I'm using a general multi-viscosity oil currently, 10W30 I think it is. The engine has now run for a total of probably 15-20 minutes, and I've seen the oil temp just over 100F. The oil pump was assembled as per the manual, with lithium grease, but I'd think that that would have been distributed/diluted by now. I haven't verified the aft plunger, could it be an issue?
