Countersunk Rivet Pulling Technique?
Postby A10snoopy » Fri Dec 18, 2015 5:29 pm
I have just started pulling my first countersunk rivets, the CCC-42s on the leading edge of the wing forward of the spar. I am leaving a slight mark on the skin from the head of the HF pneumatic puller each time. Is there a technique to prevent this?
I am polishing the skins before riveting, so every mark is noticeable.
Paul
OneX 76
A10snoopy
Re: Countersunk Rivet Pulling Technique?
Postby Bryan Cotton » Fri Dec 18, 2015 5:46 pm
Paul,
What if you took a scrap piece of .025 or .032 and put a #40 hole in it? Put the scrap between the puller and the rivet. You could put a piece of tape on the bottom of the scrap too for scratch prevention.
Postby marsolgp » Fri Dec 18, 2015 7:12 pm
I just put a piece of duct tape over the puller head, first rivet makes the hole in the tape and you're good to go..... tape does require changing every so often.
G. Marsolais
Waiex w/Turbo Aerovee
MGL Xtreme EFIS & EMS
A/P, iFly720 w/ADS-B
marsolgp
Postby SNX1508 » Sat Dec 19, 2015 6:33 am
A10snoopy wrote:I have just started pulling my first countersunk rivets, the CCC-42s on the leading edge of the wing forward of the spar. I am leaving a slight mark on the skin from the head of the HF pneumatic puller each time. Is there a technique to prevent this?
Paul
OneX 76
All of the methods already mentioned here will work well, but you could also buy a rivet puller that has tapered nose pieces, it took me awhile to find one, ended up buying a Stanley model from Farm & Fleet. The tapered nose pieces fit my pneumatic rivet puller. No tape to replace etc.
Terry
Sonex #1508
AeroVee #0736
http://www.mykitlog.com/SNX1508
Terry
Sonex #1508
N296SX
AeroVee #0736
Tail Dragger
SNX1508
Postby A10snoopy » Mon Dec 21, 2015 9:47 am
Bryan, G, Terry:
Thanks for the suggestions. I tried them all but had the most success with putting a narrow tip on my pneumatic puller. Never occurred to me the hand rivet puller tips would be interchangeable, and I had one tip the exact size of a CCC rivet. Right outboard wing complete! Thanks again.
Paul
OneX 76
A10snoopy
Users browsing this forum: Google [Bot] and 73 guests
