Dear Grammaxy, Darick and Bryan,
Before any use on the construction of a full airplane, a project has to be mounted which tests and reports the strength, aero and environmental characteristcs of the test wing sections. Some official review of those results would indicate whether such a method might be appropriate. A constructed wing would have to pass FAA tests to get an airworthiness certificate and it would be as true EXPERIMENTAL not ELSA or LSA. You can look at that project at
http://www.schwenn.com to see what's proposed (I'll make it public so you can get in to view it, Please as a courtesy stick to home, illustrative example and project definition pages - thanks.
Because this forum is for Sonex airplanes, I won't go on about non-standard (for small planes) construction methods, but that website will record changes and results.
Rotax has the necessity and resources to pursue the advances necessary for the 2025 fuel standards regulations (55mpg fleet mileage including light trucks). The new Rotaxes have advanced injectors, in flight modifyiable fuel/air mapping, rigid airbox of the right size, and secret sauce for piston, valve and cam details. The 915Tadds a turbocharger, but they do not have variable valve timing, (as will become standard on intake and exhaust - already Volvo, Accord, Ducati), and retain pushrod valve actuation. Rotax is conservative with its aviation engines. The small light Volvo T6 2-liter is already being sold and employs the likely to be widespread multi-speed electric supercharger, turbocharger, variable valve timing on all valves,... Configurations will get stranger, e.g. two pistons in each cylinder.
My Avatar - which I will try to learn how to get right within the 16KB limit. Its an "AhrViyX" (seaplane in this case) meant to demonstrate that using the noted project's lightening cycle, light efficient engine and laminar flow scheme, a 4 seater aluminum plane can be powered with the 915T. (That example isn''t design magic because the initial design weighs 1700 lbs empty and carries the oft-chosen 500# engine.) This Seaplane design has no pylons or sponsons or other high drag add-ons. It floats by virtue of its drooped wings, a seaplane hull, and its inverted V-Tail's fat tip's. The ring prop (seaplane or not) is protected by the V-tail but it would also permit over time the straightforward substitution of hybrid then battery (when ready) power in the nose: (you may need to pan or zoom to see the whole thing.)
Regards, PTHS
