Does the rocker arm really rotate the valve stem?
Postby gammaxy » Tue Dec 01, 2015 11:16 pm
The manual tells us to align each swivel pad off center in order to rotate the valves. Looking at the wear on my valve stems, I'm pretty confident than in 120 hours none of them has ever completed a single rotation. Anyone have any evidence otherwise?
Re: Does the rocker arm really rotate the valve stem?
Postby SonexN76ET » Tue Dec 01, 2015 11:33 pm
My valve stem ends look similar to your picture Chris. Maybe they will start to rotate after the valves loosen up in the valve guides.
Did you ever find out the cause of the metal flakes or oil analysis anomaly?
Jake
Sarasota, Florida
SonexN76ET
Postby Klimek » Wed Dec 02, 2015 10:39 am
I replaced all my valves at 37+- hours. All my valves looked like yours on the
end. None appeared to be rotating. Reason for replacing? After adjusting the
Valves 5 times and finding them tight each time, I was concerned about the stems
Stretching or face / seat distortion. Cylinder leak test showe #1 had higher leakage, 80/65.
The others were 5 or less.(80/75~) I found #1 exhaust sear 25% wider than the others and
It appeared none were rotating. Also all exhaust valve faces were deformed . Now I have 43+-hours and adjusted the valves at
1 hour and 5 hours after replacement and did not find any tight after a 3:34
Flight. Do not have info on rotation yet. Plan on checking valve stems
10 hours after the replacement.
Frank
ONE 090
N1970T
43 hours and counting
Klimek
Postby gammaxy » Wed Dec 02, 2015 11:30 am
SonexN76ET wrote:Did you ever find out the cause of the metal flakes or oil analysis anomaly?
I decided to answer your question in my original thread: http://sonexbuilders.net/viewtopic.php?f=7&t=2471&p=18984#p18984
Postby gammaxy » Wed Dec 02, 2015 12:42 pm
Klimek wrote:After adjusting the Valves 5 times and finding them tight each time, I was concerned about the stems Stretching or face / seat distortion.
I've re-lapped the exhaust valves on cylinders 1 and 3. I could tell cylinder 1 was leaking while turning the propeller by hand. I just did cylinder 3 since I had the head off anyway and detected a slight leak after testing it with alcohol. I did not notice any exhaust valve face distortion. Did you take any pictures?
Mine also seemed to get tight, but I think I only noticed it after retorquing the head nuts. I haven't noticed any valve stretch and think it was just due to slowly crushing the copper gaskets. I ran out of adjustment on cylinder 1's exhaust rocker and couldn't quite achieve .006" before making new pushrods. This might be how I ended up with the first leak.
Postby mike.smith » Thu Dec 03, 2015 11:38 pm
I have never seen any evidence of my valves rotating. When I had a valve job done by an engine shop they said they know about the direction to offset the two, but advised they have never seen valves rotate, and believe it to be an old wives' tale.
Postby rizzz » Fri Dec 04, 2015 12:08 am
Again, opinions seem to vary on this subject.
My local VW guy tells me to get the rocker arm adjuster dead center on the valve stem, that's contradicting the AeroVee manual.
This guy in this video is also considered a VW guru on the various forums:
https://www.youtube.com/watch?v=PIb32NNrl7s
He also seems of the opinion that the rocker needs to be centered on the stem.
He has many other very educational VW engine related videos BTW, very interesting to watch.
Postby nwawingman » Fri Dec 04, 2015 8:11 pm
Great video! Thanks for sharing. Always find it valuable to hear from others experiences. The valve ball type adjusters breaking he spoke about seemed concerning to me. Seems like I remember someone on the sonex forum having one break.
Rick Wantz - Arkansas
nwawingman
Users browsing this forum: Bing [Bot] and 62 guests
