Klimek wrote:After adjusting the Valves 5 times and finding them tight each time, I was concerned about the stems Stretching or face / seat distortion.
I've re-lapped the exhaust valves on cylinders 1 and 3. I could tell cylinder 1 was leaking while turning the propeller by hand. I just did cylinder 3 since I had the head off anyway and detected a slight leak after testing it with alcohol. I did not notice any exhaust valve face distortion. Did you take any pictures?
Mine also seemed to get tight, but I think I only noticed it after retorquing the head nuts. I haven't noticed any valve stretch and think it was just due to slowly crushing the copper gaskets. I ran out of adjustment on cylinder 1's exhaust rocker and couldn't quite achieve .006" before making new pushrods. This might be how I ended up with the first leak.
