by jwd3ca » Sat Nov 21, 2015 2:54 pm
This is a very interesting and topical thread as I get ready to start my engine for the second time (after dealing with a perceived 'tight' initial assembly, see previous posts). I have an old mechanical gauged temporarily attached via copper tubing to the port on the forward r.h. engine block, as well as my E.I.S. electrically connected to the oil pressure sender supplied by Sonex. With plugs removed, spinning over via starter only, I'm seeing the mechanical gauge gradually peg itself at over 100 psi. Whether it is accurate or not, I don't know, as it was just kicking around the shop, but the EIS seems to verify high pressure (gradual climb to ~99). I'm wondering if maybe I've messed something up as far as the two pressure relief valves are concerned?
jwd3ca on Sun Nov 22, 2015 10:34 am, edited 1 time in total.
