I'm having an issue where the triangle-shaped trim spring weldment on the control stick assembly is scraping the bottom of my seat pan (Waiex with standard lowered seat.) I can't bend the weldment down any farther because the cross bar that connects the ailerons is already contacting it when I input full right aileron. Anyone else had this issue?
The pics below show the control stick and trim weldment with full right aileron input. This is with the wings installed and I can tell that the ailerons are not quite at full deflection when the cross tie hits the bottom of the weldment, so bending the tab down would only reduce my aileron deflection.
And this picture shows that it's done to the bottom of my seat pan after just a little time spent on the ground moving the flight controls around.
The steel weldment is filing a groove in the seat pan that will eventually cut through the pan.
The only real solution I'm seeing at this point is to remove the weldment and come up with a different way to attach my trim spring to the control assembly.
