DCASonex wrote:If you have an EIS 4000, it should have connections for all four cylinders, at worst should only need a new connector, and radio Shack used to carry them. If not, am sure you could get one from GRT even if not listed as a separately available part. Installing a new plug is not that difficult if you have small soldering iron and are careful. Might also be possible to add pins into your existing plug. Might want to get more of same wire as used for your first two thermocouples for second set from GRT as well.
David A. Sonex TD, CAMit 3300, GRT EIS and Sport SX
Users browsing this forum: Google [Bot] and 22 guests
