oil
oil
Postby Sonex374 » Wed Nov 04, 2015 8:40 am
Just wondering what oil others are using.
Rutter
N374WR (Reserved)
Sonex tri-gear
Polish
Aerovee
Sonex374
Re: oil
Postby Rynoth » Wed Nov 04, 2015 9:27 am
I'm using the Valvoline VR1 20w-50 non synthetic called for in the Aerovee manual. Not too expensive by the case on Amazon.
http://www.amazon.com/Valvoline-822347- ... VR1+20w-50
About $6 a quart.
Re: oil
Postby SonexN76ET » Wed Nov 04, 2015 1:36 pm
I too am using Valvolene VR1 20w50 Racing oil. The Aerovee manual specifies the approved oils. You have to have oil that has a high zinc content. Like Ryan, I get mine by the case from Amazon.
Jake
Sarasota, Florida
SonexN76ET
Re: oil
Postby rizzz » Wed Nov 04, 2015 5:55 pm
I've been using the Brad Penn Penn-Grade 1 Racing 20w50.
My local VW guy swears by this one.
The Valvoline VR-1 20w50 does not appear to be available in Australia.
Re: oil
Postby mike.smith » Wed Nov 04, 2015 10:46 pm
Rynoth wrote:I'm using the Valvoline VR1 20w-50 non synthetic called for in the Aerovee manual. Not too expensive by the case on Amazon.
About $6 a quart.
Same for me.
Re: oil
Postby vwglenn » Thu Nov 05, 2015 9:57 am
For the last 20 years I've been using Castrol GTX 20-50 in my VWs. Haven't had an engine grenade on me yet. I'd go with whatever they recommend for the Aerovee.
Some people swear by synthetic and blends. Most of the guys I've talked to that have used them in VWs have had weeping issues (leaks) because the molecules are supposedly smaller and the tolerances on VW engines aren't as refined as modern engines. Another reason I use conventional oil is the frequency at which I change my oil. Usually 1500-3000 miles. Up until recently, I never ran a filter, only the screen. I reasoned that even expensive synthetic will recirculate the junk that gets by the screen and would be a waste of money as a result.
Glenn
Sonex #600
N889AP
vwglenn
Re: oil
Postby andrewp » Thu Nov 05, 2015 11:30 am
I don't have a VW, but I would thought I would drag the Jabiru people into this thread.
Aeroshell 100W + Camguard
Ed Kollins (the dude who made Camguard, designed or whatever) hangs out on the Cessna list. Between him and way many seminars from Mike Busch, Camguard makes a lot of sense paired to a simple oil. No idea if it has any relevance from a VW angle.
Gentlemen, start your flamethrowers.
AP
andrewp
Re: oil
Postby nwyooper » Thu Nov 05, 2015 1:15 pm
I use Valvoline VR-1 20w50 but buy it from a local distributor in Portland, OR. Cost is $4.81 per quart- find a local distributor and they will most likely sell direct to you.
nwyooper
Re: oil
Postby Gripdana » Fri Nov 06, 2015 12:47 am
I use Valvoline VR-1 20w50 as recommended in the Aerovee manual. I buy it from my local auto parts store.
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Re: oil
Postby Sonex374 » Mon Nov 09, 2015 7:03 pm
Thanks to all for your sharing your info.
Rutter
N374WR (Reserved)
Sonex tri-gear
Polish
Aerovee
Sonex374
Users browsing this forum: No registered users and 61 guests
