MGL Xtreme - Aerovee - EMS Setup
Postby Sonex1462 » Sat Oct 31, 2015 11:54 pm
I am trying to setup the EMS section for my Xtreme.
I have the Aerovee 2.1 (non turbo)
I have the Sonex CHT probes.
I have the VDO senders (oil Temp and Pressure) from Sonex.
I have the MGL EGT probes.
Can someone who has already done this share their settings?
I am having trouble especially with the RPM settings. What pulses / revs ?
Thanks
John Stewart
Sonex 1462
Sonex1462
Re: MGL Xtreme - Aerovee - EMS Setup
Postby Fastcapy » Sun Nov 01, 2015 5:42 pm
-Removed-
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby Rynoth » Sun Nov 01, 2015 5:48 pm
I'm curious about this as well. I have the iefis Discovery lite but I imagine the setup settings are very much the same using the MGL RDAC. So far I have oil pressure reading, but not oil temp and I'm not sure the RPM is registering. Is it normal to get intermittent readings below 1000 rpm?
Postby Brett » Sun Nov 01, 2015 6:09 pm
The rpm on my discovery lite has been all over the place. Hooked up exactly the same as my other engine and older Rdac with an ultra horizon xl and it reads fine . I haven't looked into it much yet but I flicked the filter on the rpm 1 switch yesterday and will try it again and see what happens. Hopefully that's all it will be.
I think I really need to spend a full day to just try and set everything up. I've sort of just been tinkering with the settings here and there.
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Postby Fastcapy » Sun Nov 01, 2015 6:17 pm
-Removed-
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
-Removed-
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby Fastcapy » Sun Nov 01, 2015 6:22 pm
-Removed-
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby Sonex1462 » Sun Nov 01, 2015 6:33 pm
Hi Mike,
Thanks for your help.
I will give these a try.
I will share my results.
John Stewart
Sonex 1462
Sonex1462
Postby Sonex1462 » Sat Nov 07, 2015 10:41 pm
Today I started my Aerovee engine. I have my Xtreme set to these settings. The readings appear to be correct now.
However I have another issue. The throttle is stuck with the engine running. The throttle moves smoothly when the engine is off but when it is running I can not move the throttle.
The engine starts right away. It seems to be running fairly smoothly.
The RPMs are around 1400
The oil pressure is 38 psi
I only ran it for a very short time period. The oil temp only got up to 89 degrees.
John Stewart
Sonex 1462
Sonex1462
