Hello SonexBuilders.net,
First, to the moderators: in all fairness, can you please change the title of this thread from "accident" to "incident" per FAA definition?
We heard from Redge yesterday and he is just fine. Very minor damage, and the cause of the gear-up was the same as John's. The square-bottom of the SubSonex fuselage makes a gear-up very uneventful, which is great! We were able to replace a couple belly skins and repair the inboard flaps on "Sharky" in only a day’s work.
Regarding the fuel spill, the SubSonex has a fuel drain valve on the belly, but it is not at the low-point of the fuselage that would have directly contacted the runway and it is not proud of the belly skin surface. I have no direct information from Redge on this aspect, but either a piece of debris, like an antenna, depressed the valve, or (perhaps more likely) the airport workers depressed the valve when lifting the aircraft.
Since the Oshkosh gear-up, John has been busy devising a very simple gear warning system -- you know what they say about the mother of invention… The LED warning light system uses an interlock between the flap handle and gear indicator. If flaps are extended with the gear-up, bright multi-color LED’s at the top of the instrument panel will flash until you extend the gear. We’ll have all of the electronic components and installation instructions for that system included in an update package to be sent to SubSonex customers next week. MGL Avionics is also working on a firmware update for the iEFIS Explorer instrument to allow a gear warning indication to show-up on the iEFIS display using a single-wire input from the gear warning system electronics package we are providing. Pre-programmed SubSonex checklists will also be available for the iEFIS Explorer avionics package soon.
- Gear Warn LED Lights (Upper Left and Right corners of panel) flash and change colors, and MGL iEFIS screen Gear Warn Indication (Flaps DOWN, Gear UP):
- SubSonex_Gear_Warn_System_3095 2.jpg (182.29 KiB) Viewed 7743 times
- Gear Warn Switch Senses Flap Position (Zero Flaps Shown Here):
- SubSonex_Gear_Warn_System_6308.jpg (205.04 KiB) Viewed 7743 times
Have a great weekend everyone, and fly safe!
Regards,
-Mark
Mark Schaible
General Manager
Sonex Aircraft, LLC
phone: 920-231-8297
fax: 920-426-8333
http://www.SonexAircraft.comhttp://www.AeroConversions.comSales Info:
sales@sonexaircraft.comOrders:
orders@sonexaircraft.comAccounting:
accounting@sonexaircraft.comTech Support:
tech@sonexaircraft.comBuild a Sonex Aircraft in Your School!
Check out the Sonex Education Initiative:
http://education.sonexaircraft.com/
