Jabiru 3300 Installation tricks/tips/gotchas
Re: Jabiru 3300 Installation tricks/tips/gotchas
Postby fastj22 » Thu Dec 29, 2011 12:21 pm
Thanks Kip. One more question, what was the rivet separation on the doublers? 1 inch?
Postby N111YX » Thu Dec 29, 2011 4:25 pm
One inch is fine. Anything that looks "JAR" (just about right) should work.
I should have the cowl off in the next week or and and I'll take some pics... ;)
fastj22 wrote:Thanks Kip. One more question, what was the rivet separation on the doublers? 1 inch?
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby N111YX » Sat Jan 07, 2012 9:31 am
Here's a pic. These were hastily built and the metal on hand was probably too thick but they work...no more cracking... :P
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby sonex293 » Sat Jan 07, 2012 10:07 am
Kip,
I've had to do the same on my J3300. Pulled the cowl recently and noticed that my patches now have cracks! I've got my conditional inspection coming up in April and I'm thinking about re-doing the baffle sides and somehow incorporating movement joints. I've still got a few months to think about it.
Michael Crowder
ex- Sonex N293SX
Current - Just Highlander N371EM
sonex293
Postby N111YX » Tue Jan 17, 2012 1:27 am
Vertical running hinge pins would probably work great where the doublers are and provide relief... :P
sonex293 wrote:Kip,
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby N111YX » Tue Jan 17, 2012 1:29 am
Adding to the above list, get one of these...
http://www.aircraftspruce.com/catalog/a ... ckdv52.php
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby fastj22 » Wed Jan 18, 2012 12:06 am
N111YX wrote:Vertical running hinge pins would probably work great where the doublers are and provide relief... :P
sonex293 wrote:Kip,
Could one just cut a relief channel and seal the gap with the red baffle tape like the front?
Postby N111YX » Wed Jan 18, 2012 1:27 am
That might work as long as the stresses don't migrate to the top of the box. Mechanically binding the structures opposite the relief cut would be best I think...
sonex293 wrote:Kip,
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby Jim » Sat Jan 21, 2012 12:38 pm
Do you have the Aerovee carb installed? If so do you have any tips on tuning it? I got mine recently, after the backorder, and can"t get tuned following their directions. I have the 2200 Jabiru.
Jim
Postby N111YX » Sun Jan 22, 2012 11:55 am
Jim wrote:Do you have the Aerovee carb installed? If so do you have any tips on tuning it? I got mine recently, after the backorder, and can"t get tuned following their directions. I have the 2200 Jabiru.
While it's a long subject that has been covered over and over in the "Yahoo" groups, the first bit of advice is don't kill your engine with heat by running it up to high power on the ground. Many people get it running decently for takeoff and finalize the tuning after seeing EGT numbers in flight. Please use caution regardless of what you do...
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Return to Jabiru
