Bryan Cotton wrote:Clearly I would need a TSO set to put on a certified airplane. Do you think I would have any issues with the non-TSO set if I wanted my A/W cert to reflect day/night VFR? A big difference from the Aveo is that AeroLED does offer TSO lights.
Sonex1243 wrote:Thanks for the clarification Mike;
I'll have to dig out the specs I received from AeroLED and bump it with the requirements. Pretty sure I will be ok. I think I'll start hitting up the FSDO next time one of the inspectors is in town doing a FAA wings presentation. Never to early to get them "primed".
mike.smith wrote:The experimental lighting manufacturers often make two versions of their position/strobe lights: TSO'd and non-TSO'd. For experimentals, position/strobe lights are one of the few areas in the FAR's that are required to be TSO'd if used at night (daytime you can do whatever you want). I'm not making that one up; it's in the regs if you actually read the wording.
Direct C51 wrote:mike.smith wrote:The experimental lighting manufacturers often make two versions of their position/strobe lights: TSO'd and non-TSO'd. For experimentals, position/strobe lights are one of the few areas in the FAR's that are required to be TSO'd if used at night (daytime you can do whatever you want). I'm not making that one up; it's in the regs if you actually read the wording.
Hmmm, Mike I sure would like to know what FARs require experimental aircraft to have TSO lights to fly at night. FAR 91.205, FAR Part 23, and the following legal interpretation does not say that.
http://www.faa.gov/about/office_org/headquarters_offices/agc/pol_adjudication/agc200/interpretations/data/interps/2014/Josephson%20-%20(2014)%20Legal%20Interpretation.pdf
Nate
