by tmobbs » Wed Feb 17, 2016 6:35 am
David et al
Did you ever get your queries resolved?
I too am installing an MGL Discovery Lite EFIS, RDAC MAP, SP6, and I have a Princeton fuel level sender from Sonex, a Funkwerke ATR833 radio with built in intercom and a Trig TT21 Transponder.
The MGL display worked nicely straight out of the box, but I have not yet managed to calibrate the fuel level sender, or get the EFIS to recognise and interact with the radio/intercom or the transponder. As I have not run my Aerovee yet, I can't tell if the EGT, CHT, Oil Temp and Oil Pressure sensors work.
If any of you have solved these problems now, please would you share your solutions?
Best wishes
Tim Mobbs
Sonex #1555 Standard Gear, Aerovee #0672
Bungay, Suffolk, England
