SonexEZ wrote:One cylinder didnt have any compression, the exhaust valve was too tight , removed the head to see if the valve was burned and it wasent I lap the valve and the seat but on installing the rocket hold down bolt snapped before it got to the 14 ' lbs, so i ordered it form sonex
I stopped at pep boys they said i had to go to a different store they didnt have anything but wippersSonexEZ wrote:Jake do i have to ask for it in pep boys or is it out in the iles ? this sonex has the canopy thta goes back over your head thanks for your help the seal that was on the canopy was on upside down
SonexN76ET wrote:Here is the weather stripping I used on the back of my canopy. So far it has not peeled off anywhere. If it does peel, I may use some aluminum rivets and washers to hold it in place.
Jake
SonexEZ wrote:SonexN76ET wrote:Here is the weather stripping I used on the back of my canopy. So far it has not peeled off anywhere. If it does peel, I may use some aluminum rivets and washers to hold it in place.
Jake
Jake i havent got the seal yet but looking at the picture how did you mount it my canopy sist just inside the bode of the aircraft , flying it home i was in the edge of a thunderstorm had a few leaks ,
Users browsing this forum: No registered users and 71 guests
