SonexEZ wrote:maybe if i had worked on small aircraft in the past 25 years instead of 727-200 and 747 i would have had more knowledge to know what to look for as one A& P to another I beleaved the A&P just did an annual on this aircraft
mike.smith wrote:SonexEZ wrote:I went to pick up a sonex yesterday in NC ,with aerovee aircraft is clean, trigear 145 hours fist problem overheats very easy if you try to clime it overheats very easy all baffuling is in place . second problem front oil leak could be front crank but not sure yet it was raining when i landed , can this be changed without splitting her case ? going to pick up with a trailer on saturday i feel its not safeto fly any distance.
There can be several reasons. When I was running hot it was almost entirely because I was running too lean. I had to change to a different needle in the AeroInjector and then do some trial and error. Once I did that all the temps dropped way down into the green. Way down! The baffling might not be sealing well. The super tin (metal baffles under the cylinders) could be misaligned. The cowl inlets and outlet might not be cut/sized properly. Is there an oil cooler? Bottom mount or top mount? Is there enough air getting to it? The secondary ignition might not be timed properly (there is a procedure to turn off the secondary while in flight to see if the temps go down). I wrapped my exhaust pipes with header wrap, and that seemed to help keep the temps a little lower. Other people may have some other ideas to check.
Users browsing this forum: No registered users and 86 guests
