Brake bleeder upside down?
Postby SvingenB » Sat Oct 03, 2015 9:35 am
I'm installing wheels and brakes and have the aeroconversion hydraulic brakes. The drawings show the supply line above the bleeder line. The bleeder line is positioned straight down. This seems very counter intuitive. I wonder what other people have done.
Reserved LN-ENX for Onex #134
Onex build log
SvingenB
Re: Brake bleeder upside down?
Postby Mike53 » Sat Oct 03, 2015 1:29 pm
I installed as per drawings and had no problem,albeit there is very little room between floor and bleeder to work with, when bleeding the brakes.
Mike
Mike
Antoine de Saint-Exupery
Mike53
Postby Bryan Cotton » Sat Oct 03, 2015 4:20 pm
Bjørnar,
I have a Waiex so I am not sure if it is different. My directions clearly showed the bleeder should be mounted higher.
Postby Mike53 » Sat Oct 03, 2015 5:31 pm
Odd that they are different? here are the drawing /instruction sheet from the Onex http://www.sonexaircraft.com/documents/ ... lation.pdf
Bleeder on the bottom.
Mike
Mike53
Postby mike.smith » Sat Oct 03, 2015 11:13 pm
I retrofitted the brakes onto my Sonex, and the bleeder is at the top. It's worked fine with no problems.
Postby SvingenB » Sun Oct 04, 2015 1:59 am
Mike53 wrote:I installed as per drawings and had no problem,albeit there is very little room between floor and bleeder to work with, when bleeding the brakes.
Mike
How did you get all the air out when the bleed outlet is at the lowest point? Do you have to pump like crazy, or do you fill it up from the bleeder?
Onex build log
SvingenB
Postby Mike53 » Sun Oct 04, 2015 6:31 am
Mike
Yes I filled from the bleeder's using this http://www.aircraftspruce.ca/catalog/lg ... kkey=16830
On my web site you will see how I improved on their design .It is a one man operation and worked great once I made the changes and used the nipple fitting supplied on the brakes.
http://www.onexmike.org/hydraulic--toe-brakes.html
Good luck.
Mike
Mike
Mike53
Postby SvingenB » Sun Oct 04, 2015 9:57 am
OK thanks. Have to look into that.
Onex build log
SvingenB
Postby TinBender » Sun Oct 04, 2015 12:10 pm
A Power Bleeder is cheaper, and I have been very happy with it for my race car, too.
http://www.motiveproducts.com/
TinBender
Postby RodgerC » Tue Oct 06, 2015 4:09 am
For a while I couldn't work out what all the fuss was about, then it occurred to me that for you chaps in the Northern Hemisphere, bubbles rise to the top. D'oh!
RodgerC
Return to Onex
Users browsing this forum: No registered users and 27 guests
