by andrewp » Mon Sep 21, 2015 5:35 pm
Mine has a climb prop and is an old hydraulic lifter. Personally I love it. One up I get 1200-1500 fpm. My cruise is limited by my prop choice, but it goes at a comfortable 140mph, 6gph approximately. Others would do better and I am sure the later versions of the jab do better. Compared to a continental o-470 or something, they are little pieces of jewellry and need to be treated as such though. You need to manage temps on them (as you do on the -o-470!)
You need to actually go for a fly in one with a 3300 to make a sensible decision, but given you understand the expense and all that, it really makes the airplane huge fun to fly. Getting the baffling right is work because it is a lot of engine for a little space. Most people end up having to shield their fuel lines etc or get rid of the gascolator. You do lose the ability to overhaul it for small numbers that you get with an aerovee. Jabirus are not perfect either they have their mechanical issues. You might want to hang out of the jabiru forum.
Let's put it into context: Our sonex sits in a hangar. Our old 182 that we have been slowly fixing up sits on the ramp (which is wrong, but that tells you how much we love our sonex).
If you have a corvair in it (? - not sure if that is right or if I am confusing you with someone else), you might want to see what you can do with it before throwing the baby out with the bathwater and only you will know what makes you happy... YMMV!
Cheers,
Andrew
