Rynoth wrote:I seem to recall something similar on one of my wings, with most of the pressure focused on the forward tip of 1 or 2 wing ribs. I rounded the tips of those ribs slightly to keep them from poking into the skin too much, then just made sure the skin was pulled snug before pilot drilling.
rk2436 wrote:If you are using the kit skins then yes this is a common problem. The leading edge radius is too big. I remember trying to split the difference between the upper and lower sides. If possible try to have the bigger dimples on the underside if possible.
Bryan Cotton wrote:The issue I see is the skin is not very tight on the two most forward holes on the bottom of the leading edge. I think I will have dimples there. I suppose better on the bottom than the top.
Users browsing this forum: No registered users and 31 guests
