Sonex1517 wrote:Ryan
I just went through this a few weeks ago. All I can say is it was a mystery to me too.
I ended up not installing the bottom piece after consulting with the factory.
The rest simply did not fit correctly so I did what I could to make it fit. The exhaust, for example, was way off the pre cut holes. I am guessing this is because I have a turbo kit with a different style exhaust, but could be builder error. (That would be me)
In the end it was a slow and frustrating process but I got it installed. I did end up using nut plates and screws to make it easy to remove, and so far that has paid off.
Chicagoland
N1517S reserved
rizzz wrote:Hi Ryan,
I used the AeroVee fence baffle kit on my 2.4L VW engine. it required some modification as my engine is wider and the cylinders are shaped differently.
Anyway, here are some pictures of my installation which might answer some of your questions:
Users browsing this forum: Bing [Bot] and 79 guests
