Panel Layout Finished
Panel designs, construction methods, and pictures
Re: Panel Layout Finished
Postby wlarson861 » Sat Aug 29, 2015 10:58 am
SonexN76ET wrote:Bill,
What type of keyed switch did you use for the master switch? I have been thinking about using a keyed switch for quite some time now and figure it is time to put one in. My problem is I have not been able to find one that I consider robust and reliable enough. I appreciate any suggestions.
Jake
Like this one from Amazon
http://www.amazon.com/Key-Switch-with-2 ... yed+switch
http://sonexbuildersandpilotsfoundation ... #h31f901f9
Bill Larson
N861SX
wlarson861
Postby Gripdana » Sat Aug 29, 2015 8:35 pm
I used a simple starter switch in place of a push button starter switch. I just wanted to keep it simple.
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Postby rdsafe » Sat Aug 29, 2015 8:46 pm
Dana;
Pray tell; what's the difference between a simple starter switch and a push button starter switch:
Richard Stauffer
rdsafe
Postby Gripdana » Sat Aug 29, 2015 8:54 pm
It is a regular keyed ignition. I simply used the momentary side as the starter switch. It does nothing else. It only prevents the use of the starter without the key.
Dana Baker
Scratch Built
Gripdana
Postby jjbardell » Sat Aug 29, 2015 9:37 pm
Dana, So you have a key instead of a starter button...on the Aerovee? You explained it so simple, seems to make complete sense. Why is this not the norm out there? Why would anyone want a button, which can be used by anyone when a keyed ignition alone is doing both?
Example. Could I simply replace my starter button with this?
http://www.amazon.com/Momentary-Key-Swi ... key+switch
Because that just looks cool and is safe. Especially since I may be sharing a hanger with a stranger.
N83LJ - Sonex #0864 (SOLD)
jjbardell
Postby Gripdana » Sat Aug 29, 2015 10:57 pm
Here is the switch I used. It is a standard automotive ignition switch. I only hooked up the "starter switch" part.
Dana Baker
Scratch Built
Gripdana
Postby wlarson861 » Sat Aug 29, 2015 11:52 pm
jjbardell wrote:Dana, So you have a key instead of a starter button...on the Aerovee? You explained it so simple, seems to make complete sense. Why is this not the norm out there? Why would anyone want a button, which can be used by anyone when a keyed ignition alone is doing both?
The short answer is yes On mine I have a key that is in series with the master switch. Since I'm hangared and the canopy is always locked when traveling, I leave the key switch on and the key in it. I only turn the key switch off and take the key when the canopy is open at fly ins. The reason I didn't use a key starter switch was I can't count how many times I got in the Cardinal and strapped in to realize the keys were in my pocket. When I use the master key and take it while I fetch pancakes at the fly in I always put the key in my shirt pocket so I can get to it without unbuckling. I like using just a toggle switch 99% off the time.
Bill Larson
N861SX
wlarson861
Postby GordonTurner » Sun Aug 30, 2015 4:34 am
I plan a similar arrangement, but will put the keyed on/off (not momentary) switch in line with the momentary push to start button. Normally the key can just stay in and "on" but when I want to disable the start I can turn it off and take the key.
I didn't want ANY extra complication on the master side where my ignition is powered.
GordonTurner
Postby wlarson861 » Sun Aug 30, 2015 11:20 am
By putting it on the master circuit I don't have to worry about someone turning on the master switch and draining the battery. Either way will prevent the danger of someone swinging the prop.
Bill Larson
N861SX
wlarson861
Return to Panel
Users browsing this forum: No registered users and 56 guests
