kmacht wrote:Anybody able to get the dial a trim to work for both solo and gross weight. If I set it up the rear spring for gross weight I have just enough nose down trim before running out of dial but when I fly it solo I run out of nose up dial when setting up to land. If I adjust the rear spring the other way for solo flight I'm good when setting up to land but have to hold alot of forward stick when I get to gross weight. I'm a bit dissapointed in the system as it seems there isn't enough travel in the dial no matter where the rear spring is set.
Users browsing this forum: Google Adsense [Bot] and 63 guests
