by wlarson861 » Mon Jul 13, 2015 12:44 am
First thing is the engine is not broken in until about 50 hours. Mine would creep up over 400 degrees even in shallow climbs for at least the first 25 hours and then slowly improved until around 40 to 50 hours. The mixture is also important. Running lean in the early hours will compound the CHT heat problem. Even after being well broken in I could get the CHT high by leaning too agressivly. Make sure you have wheel pants and any other fairings installed, they make a huge difference. Use climb attitude and mixture to keep heat down until well broken in and you will notice a big difference. The advice on checking for the right amount of cooling exit is also something to investigate. I opened mine and that helped.
After 25 to 50 hours if you see a big difference between the front and rear cylinders, I used an air dam to partially block the front cylinders and force more cooling air to the rear. This seemed to raise the front a bit but also lowered the rears, equalizing them better.
Bill Larson
N861SX
