Who has a running Aerovee?
Re: Who has a running Aerovee?
Postby fastj22 » Fri Dec 23, 2011 11:02 pm
Here's how I would trouble shoot it.
Remove a plug from each cylinder.
Get a cheap compression gauge from HF or auto parts store.
Screw it into cylinder #1
Hand turn the prop at least 720 degrees.
That will mak sure you get one compression stroke.
Check the gauge.
If you get a good reading, move it to the next cylinder. Repeat.
If you don't get a good reading, it's either a valve, head or ring issue.
Focus on one cylinder at a time.
I suspect it's probably a valve adjustment issue. If you have them too tight at the rocker, they won't seat properly.
Postby uteboy » Sat Dec 24, 2011 7:36 pm
Sounds like it could be way to lean. Have you tried giving it a squirt of something like easystart?
I bet its something simple. Are the plug leads on the right plugs? I got plug wires mixed up once. Felt a right plonker when it finally fired right up.
uteboy
Postby MichaelFarley56 » Sun Dec 25, 2011 6:13 pm
Merry Christmas Everyone!
I haven't had a chance to fill everyone in on my engine issue, but I finally found my problem. Thankfully Sonex and the Aerovee parts are fine...but my building procedures leave a little to be desired. Long story short, when I bolted on my camshaft gear I bolted it 120 degrees off of where it should be, leading to my timing issue. I was able to access these bolts through the oil pump housing but now I will need to remove (hopefully) one cylinder to file the camshaft a little where a connecting rod is hitting the cam. If this would happen to work I should have everything back up and ready for another first start attempt in a few days.
Sorry if I misled anyone...the engine seems fine it's a stupid builder that's the problem!
I'll post a better engine review as soon as I get this engine running.
