Aeorvee Ignition System Woes
Postby Fastcapy » Sun Jun 28, 2015 9:32 am
-Removed-
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Re: Aeorvee Ignition System Woes
Postby mike20sm » Wed Jul 08, 2015 2:42 pm
I was also curious about the failure of a solid state magnetron and found this possible clue here:
Ignition Module Failure
Because the ignition module is electronic and does not utilize moving components, it is normally one of the most reliable part of the engine. When it does fail, it is usually due to heat caused from improper wiring of the ground wire to battery voltage.
http://www.briggsandstratton.com/us/en/support/faqs/ignition-system-theory-and-testing
Standard Sonex kit #1692
preparing workshop for arrival
http://websites.expercraft.com/mike20sm
mike20sm
Postby Fastcapy » Wed Jul 08, 2015 4:07 pm
-Removed-
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby NWade » Wed Jul 08, 2015 4:31 pm
Mike (& others) -
On the subject of spark-plugs, resistance, etc, Mike Busch has a decent webinar on Spark Plugs here:
http://www.eaavideo.org/video.aspx?v=1826468805001
And there was a recent development with Champion spark-plugs, as Mike commented on here:
http://blog.aopa.org/opinionleaders/201 ... cceptance/
--Noel
NWade
Postby Sonex541 » Wed Jul 08, 2015 7:49 pm
Always use njk plugs and so far no issue.
Sonex541
Users browsing this forum: Bing [Bot] and 33 guests
