gammaxy wrote:Glad you figured it out--as frustrating as it is, I'm sure its nice for the problem to be something clear-cut. Do you feel like this is a satisfying explanation for the rough running also?
Yeah, at least I know.
It certainly does not explain the rough running.
Since the weekend I have checked the timing of the dual magneto but that all appears to be good.
The valve timing as Jake mentions below was correct as well, the dots on the crankshaft gear vs. camshaft did align. (I'm assuming that's what you mean Jake?)
It could be fuel as someone mentioned as well, the AeroCarb was installed with the #2 needle and initially set as per the instructions, but no adjustments done yet.
The other thing is spark plugs.
Mine were not new.
I found a set of 8 REL38B's on Ebay, they were sold in an "as new" condition but who knows with Ebay stuff.
The REL38B's have now been superseded by the REL37B so I will buy me a brand new set of those from spruce I think.
