saddler wrote:I have a question for you guys with hydraulic brakes. I recently filled my master cylinder with fluid and bled the brakes for the first time. I have the sport trainer (center flap and brake lever) control setup. With the brakes bled, there is little movement in the lever on the master cylinder before there is heavy resistance. Therefore, I get no where even close to the full brake lever travel to the parking brake position. I am struggling with a fix for this. I assume that the throw on the master cylinder is correct? The problem with center controls and a hand brake is there aren't enough hands to do an engine run up without having the parking brake position. So, I'm wondering what you guys do or have you run in to this same problem and if so, what is your solution?
