merle reppert wrote:Make sure the oil drain passage in the case is not blocked by sealant ??
vwglenn wrote:Well I don't know about the Aerovee flywheel but the regular flywheel on a VW has an O ring on it...
[/img]
Usually when the main seal isn't leaking, the cam plug can be the culprit. Drips down, hits the flywheel and throws oil all over the place.
SonexN76ET wrote:Mike,
I don't remember for surer, but double check that their is not supposed to be an o ring on the flywheel. I just don't recall.
rizzz wrote:Mike,
Check out this post on the legendary Bob Hoover VW blog:
http://bobhooversblog.blogspot.com.au/2 ... -seal.html
It might explain some things.
Users browsing this forum: Google Adsense [Bot] and 43 guests
