It took me some days to find the courage to post this, it still hurts looking back, but here goes.
I’ve had another serious problem with my VW engine, this weekend I started the thing for the first time and it ran really rough.
I was not able to get any power at all out of it so I took the plane back into my garage to investigate. Anyway, here’s a short video:
https://www.dropbox.com/s/1jsdsm4f0d6qy ... 0.mp4?dl=0(This is a link to my dropbox so this won’t be on there forever, download a copy if you want to keep it for reference).
Sounds like a timing issue?
Unfortunately, that was the good news.
The bad news however is that after this I had damage, my Force One prop hub bearing had spun. It was moving along with the crank.
I couldn’t believe it, I have to rebuild this engine a second time now (others may have followed my previous incident on the VW aircraft forum).
Nothing I can do about, I took the engine off the plane and opened it up, dreading to find out what damage was done inside.
Anyway, here’s what it looks like, the F1 hub & bearing are toast, the case also took damage at the dowel pin insert. Everything else appears to be intact.
How could this have happened, was the rough running (possible timing issue) the cause? Did the bearing get such a nasty kick it got smashed out of its seating?
I contacted Scott at Hummel engines and he seems to think it would rather be either an oil delivery problem to the F1 bearing or the bearing was just too tight, I’ll need to investigate.
I’m also talking Marty at Great Plains.
Again I must say, both Scott at Hummel and Marty at GP are great guys. Excellent customer service.
Even though my engine is a bit of a mixture of both their products they are both keen to help me just resolve the issue rather than try to sell me stuff (which is what commonly would happen here in Australia).
Scott seems to think the case could perhaps be salvaged by machining out the dowel pin hole and use a “stepped” dowel pin (larger on one side) instead. A machine shop can make one if necessary.
I’m not quite convinced yet I’m comfortable with that idea but I’ll take it to a machine shop and see what they say about this. Worst case I might throw away the case and get a new one altogether as well (again!).
As said the F1 hub and bearing are going into the bin as well but the crank should be good, I’ve taken that to the local engineering shop to get the hub pressed off, I’ll know for sure if it’s good once I get it back.
Painful, very, very, very painful…
I was so close to moving my plane to the airport, this was the last thing that had to be done…
Luckily my wife and I are going on a nice tropical holiday next week to celebrate our 10Y marriage anniversary so I can take some time to away from this as my head is not in a good place for the moment.
