billmaxmcw wrote:I also have had a lot of lead buildup, so I'm now using TCP in the fuel to try to lessen that. I also leaned aggressively. But when I pulled the head after an exhaust valve leak, the local VW mechanic thought that was due to over-leaning. Now I run EGTs in the upper 1100s rather than mid 1300s.
Bill
billmaxmcw wrote:Now I run EGTs in the upper 1100s rather than mid 1300s.
Bill
Sonex541 wrote: I looked under it and the push rod tube was bent and leaking oil. I pulled it apart to find a broken push rod and stuck exhaust valve.
Adam Simmons
Sonex 541
Users browsing this forum: No registered users and 34 guests
