nwawingman wrote:Thanks Mike! That make me feel better. Maybe I do have an issue after all. My rear cylinders also looked like they were running leaner than the front. # 4 looked to be running the most rich. I will let you know how my readings are when I get them reinstalled.
tom0nex74 wrote: I am experiencing leaning (higher CHTs & EGTs) when pitching the nose up in climb. Does anyone think that the pitch angle of the Aeroinjector could cause a leaner mixture?
Rynoth wrote:I use the following from Aircraft Tool Supply. Works great. The adapter fits in the Aerovee plugs.
2E DIFFERENTIAL CYLINDER PRESSURE TESTER (18MM) 1 $69.95 $69.95
12MM ADAPTER, 2E PRESSURE TESTER 1 $8.95 $8.95
Users browsing this forum: Google [Bot] and 12 guests
