This is something that I've been wanting to understand better about the Sonex.
There are many references that say "The best rate-of-climb and angle-of-climb is
always reached with flaps up." I personally am uneasy about claiming this statement is always true, but it seems to have always been true for everything I have flown in my limited experience.
When you have more power than required for your airspeed (and hold airspeed constant by controlling pitch), the extra power is converted into gravitation potential energy (altitude). Adding flaps increases the drag, so more power is required for a given airspeed and you climb slower than you would without the use of flaps.
Since flaps reduce your stall speed, they allow you to begin climbing sooner in the takeoff roll than otherwise. From that point, there is a range where you are higher above the ground than you would have been using 0 flaps. There is a crossover point further away where the identical airplane without the use of flaps will outclimb you. I think knowing where this crossover point is would really help in making the decision between 0 and 10 degrees of flaps. I am curious about how precise I have to fly if I want to significantly benefit from the use of 10 degrees of flaps in the Sonex.
nwawingman wrote:I have always added one notch of flaps when taking off of grass and when I am near gross weight. At gross weight it seems to help when raising the tail for better acceleration and climb out. Once I have climbed to safe altitude I will raise them and climb at normal climb rate.
When I take off from grass, I notice that the airplane seems to accelerate significantly slower than from pavement, so in this case I would also use a notch of flaps (but switch back to 0 when I have enough speed and have cleared all obstacles). In general, on pavement, I don't use flaps at all, but would like to more precisely understand exactly what I could gain by doing so. I like to climb on the fast side of Vy to give myself a little extra time to react to engine trouble (and it helps in cooling).
