Rectorseal #5 for fuel fittings
Postby Rynoth » Wed Jun 17, 2015 4:54 pm
Anyone have experience using Rectorseal #5 for fuel tank and fuel line fittings? The specs say it's good for fuel (leaded or unleaded), it's inexpensive and I plan to use it for my fittings (in place of the ambiguous "teflon paste" called for in the plans.) It lubricates the threads and has a soft set. Just want to check in on others' opinions.
http://www.homedepot.com/p/Rectorseal-1 ... /100144191
http://www.rectorseal.com/pds-pdf/dsno5.pdf
Re: Rectorseal #5 for fuel fittings
Postby tonyr » Wed Jun 17, 2015 6:16 pm
Rectorseal ?
Sounds like something for haemorrhoids.. :lol:
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Postby Waiex 49 » Wed Jun 17, 2015 6:46 pm
Hi Ryan,
I don't know if Rectorseal would be ok or not.
A good product to use is Fuel Lube:
http://www.aircraftspruce.com/catalog/c ... ckkey=9406
By the way, I really like your web site.
Thanks for your posts on the swing back canopy installation.
I got my kit from ASA and plan on doing this mod this winter.
Good luck with your build!
Don Bowen
Viking Waiex N49YX
http://www.mykitlog.com/donbowen
Waiex 49
Postby gammaxy » Wed Jun 17, 2015 9:38 pm
I'm not completely sure how I ended up using Rectorseal #5, but that's what I used. I cleaned the fuel filter recently (~95 hrs total time and probably 80 hrs since I checked it last) and there were some yellow specks that seemed like they might be Rectorseal, but they didn't seem like anything that could be an issue. There also don't seem to be any leaks.
No idea how it compares to Fuel Lube.
Postby Rynoth » Wed Jun 17, 2015 10:20 pm
Thanks Chris. Biggest question I've come up with is how well it might hold up to higher temps firewall forward. For the fuel tank though, it seems to fit the application.
Postby Sonerai13 » Thu Jun 18, 2015 9:59 am
+1 for Fuel Lube for all fuel line fittings.
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Postby kevinh » Thu Jun 18, 2015 2:26 pm
I used fuel lube for all my fuel connections on my previous homebuilt (firewall forward and aft). 500 hrs and no leaks and connectors are easy to disassemble without gunk.
kevinh
Postby Rynoth » Thu Jun 18, 2015 6:20 pm
Appreciate the input. I did use rectorseal #5 on the fuel tank fittings, and have ordered fuel lube to use on the rest, thanks to your recommendations and its high-temp capability.
Postby saddler » Sun Jun 21, 2015 11:03 am
FWIW, a couple local A&P's recommended Tite Seal to me for these fittings and others. It looks similar to what Joe recommended. I have used this stuff on everything and it is awesome! Just another option. I have the medium weight.
https://www.aircraftspruce.com/catalog/ ... kkey=23262
Sean Saddler
Troy, OH
Waiex #165
First Flight 10/16/2015
https://www.facebook.com/Waiex165?ref=hl
saddler
Users browsing this forum: Google Adsense [Bot] and 40 guests
