by SNX1508 » Sat Jun 06, 2015 6:43 am
[quote="Johns"]Got a new wooden prop for the Sonex. Have a Force one hub on the Aerovee. The indent on the back of the prop is 1/4 of an inch small. Is the Force one hub wider or did I get the wrong prop?
John[/quote
You have the Sensenich wood prop from Sonex? I have the Sensenich W54JV5L-44G (glass), and I was fabricating the spacer yesterday in preparation for starting the fiberglass cowl installation, the Sonex plans show the spacer cut out on the back side to fit over the prop hub, and I checked the back of the prop, it is smooth with no indentation at all. So in this case the hub diameter would not matter. Unless my prop is incorrectly built, which I was wondering about because the plans say there should be 1/8" to 3/16" gap between prop (and fabricated spacer) and cowl. In my case this does not make sense, as the rear of my prop, with no indentation, will be entirely in front of the hub.
My Sonex hub OD is 5 3/4".
Terry
