by DCASonex » Sat May 30, 2015 4:42 pm
One general caution applicable to transporting most planes, tie down the main wheels and not the fuselage. The gear will soak up bumps, but unyielding straps over the fuselage will cause damage. When moving mine, tail over hung trailer, so I supported tail of mine in a cradle lined with 3+" thick old foam mattress cut up to suit, double layer on bottom, one section went over top for tie down strap. With no gear to flex in cradle,, tie down strap with ample padding is okay. This will not apply to you, unless you want to cradle the tail.
