Drill size for AN3-10A, 11A, 15A and 20A Bolts
Discussion for Onex builders on specific plans page experience. These posts are limited to technical suggestions such as assembly order, challenges, or techniques related to specific plans pages.
Postby dhogue » Fri May 29, 2015 5:49 pm
Hello all,
I am ready to up drill the bolt holes through the Forward Center Wing Spar stack-up per plan pages ONX-W16 and ONX-W13.
Is there an optimal drill size to use for the holes these bolts fit into?
The bolts are:
AN3-10A
AN3-11A
AN3-15A
AN3-20A
AN525-8R20
Bolt diameter (measured) = .186 inches = 4.73 mm
Don
Don Hogue
Onex 0173: Tailwheel: AeroVee Turbo.
Horiz/Vert Stabs, Rudder/Elevators, Fwd/IB/OB/Aileron Bellcranks on Ribs and Main Fwd/Aft Center Wing Spars, Fuselage : Complete.
WIP: Wings
dhogue
Re: Drill size for AN3-10A, 11A, 15A and 20A Bolts
Postby dhogue » Sat May 30, 2015 10:44 am
After a search of 'drill bits' I will use a leveled drill press to drill these bolt holes.
I believe 3/16" is the right diameter drill bit to use.
I'd appreciate any good feedback.
Don
Don Hogue
WIP: Wings
dhogue
Postby Sonex1517 » Sat May 30, 2015 11:16 am
Hi Don
3/16" worked well for me
Chicagoland
N1517S reserved
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby Concorde » Sat May 30, 2015 3:14 pm
Are you going to use 3/16 Reamer or drill bit ?
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Postby dhogue » Sat May 30, 2015 5:24 pm
Thanks Robbie.
Concorde,
Drill. Is there an advantage to the reamer?
Much appreciated gents.
Don
Off to the hardware store it is.
Don Hogue
WIP: Wings
dhogue
Postby rizzz » Sat May 30, 2015 7:14 pm
The reamer vs drill bit debate has been had over and over again.
Yes you can get better quality (tighter fit) holes drilling slightly undersize and then using a reamer, however, it does take more time and effort and it's easy to stuff up a hole as well.
Anyway Jeremy Monett (Sonex CEO) stepped in on the discussion on the old forum at one stage. He said that if proper care is taken, you should be able to complete your whole Sonex aircraft without using a reamer at all.
A 3/16 drill bit will be fine for your AN3 bolts.
rizzz
Postby DCASonex » Sun May 31, 2015 9:14 am
Reamers may not be required, but over the years I have found that a low cost set of 0.001" under - over reamers one of the more useful tools to have on hand.
DCASonex
Postby dhogue » Sun May 31, 2015 9:33 am
Thanks guys for the useful information. I will experiment, with both, on scrap stock.
Don Hogue
WIP: Wings
dhogue
Return to Onex Plans
