I've been having intermittent problems with my Jabiru 3300 voltage regulator (the stock Kubota model, PN RP201-53710). Over the past 30 hours or so I've had times where the regulator didn't seem to produce enough charging voltage, and times where it raised up to unacceptably high levels. To give you an idea of the variability I saw, regulator output on the low end was below 12.0 volts, even at high rpm, and on the high end was over 15.0 volts (when the over-voltage protection circuit would disconnect the alternator). Clearly something was wrong.
I conducted some initial troubleshooting, including verifying the voltages I was seeing on my Skyview matched an independent volt meter reading, and inspected all the connections and wiring from the alternator (AC stator) wires and the voltage regulator connectors. Nothing obvious was found, but each time I fiddled with things the problem seemed to go away for a short time, ultimately to reappear.
Searching on the VAF site, some of the RV-12 guys reported good success swapping the stock Rotax 912 regulator for a replacement unit. This unit is similar to the Kubota model, but has a higher output voltage (approx. 14.5 volts, vs. approx. 13.9 for the Kubota regulator). I recently swapped out my old Kubota regulator for the new model and have been flying it with good results. The output voltage has been stable, and the battery seems to charge well. In fact, even at low rpm I see higher voltage output that the old regulator, and the battery must like that.
The new unit looks very similar, and has the same bolt mounting pattern as the Kubota, but features fast-on male terminals rather than wires and a pigtail+OEM connector like the Kubota. The new one uses a case ground, but the rest of the connections are similar (the Kubota "ignition" (AKA voltage sense) wire is labeled "IGW" on the new one).
I use a "Caltric model R11-2, PN LD1293111RV", but it's listed as a replacement for the "John Deere Mower F915, AM101406". There are others that look identical on Amazon and Ebay, and I have now idea if one brand is better than another. All I can say is mine is working well so far, and I'll report again after 50 hours, or if problems resurface.
https://www.amazon.com/Caltric-Regulato ... B008HTBHUIhttps://www.ebay.com/itm/Regulator-Rect ... 2749.l2649
- s-l500b.jpg (33.06 KiB) Viewed 12670 times
edit August 2019: follow-up posted at:
viewtopic.php?f=8&t=5076------
Jeff
