I am attempting to get a Sonex Stratomaster resistive fuel probe working and am experiencing some strange behaviour.
If I look inside the probe, the green wire is connected to an output labelled Vout on the probe's circuit board. I would not expect to be using a voltage output with a probe that is configured to deliver a resistive load. I am wondering if the probe has been supplied with the green wire connected to the wrong output from the board. Can anyone confirm if the green wire ought to be soldered to the unused pad labelled 'MGL' on the PCB.
Picture of the inside of the black box:
