Leak check
Leak check
Postby Bryan Cotton » Sun May 17, 2015 5:54 pm
I am considering filling my tank with water for a leak check. Any thoughts? On the C140 I was restoring I used air pressure but that is scary.
Re: Leak check
Postby Brett » Sun May 17, 2015 6:07 pm
Petrol is a lot thinner than water. Petrol could leak where as water may not... plus would take quite some time and effort to dry it out...
Just a thought...
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Re: Leak check
Postby gammaxy » Sun May 17, 2015 6:36 pm
I left water in my tank for a few days before installing it in the airplane. It proved I had no major leaks, but I still ended up discovering a small leak once I added 100LL (an extra quarter turn on the fitting stopped the leak).
Chris Madsen
Aerovee Sonex N256CM
Flying since September 2014
gammaxy
Re: Leak check
Postby sonex892 » Sun May 17, 2015 7:04 pm
Bryan Cotton wrote: On the C140 I was restoring I used air pressure but that is scary.
Bryan. I agree, air testing with too much pressure would no doubt be scary.
I would still be checking with air, just at an extremely low pressure. It is in my opinion the best way to test for leaks. Tape a balloon or glove to one of the fittings, you only need enough pressure to inflate the balloon which will also act as a pressure relief valve. Spray soapy water around the fittings to check for leaks.
Steve
Sonex 892
sonex892
Re: Leak check
Postby mike.smith » Sun May 17, 2015 7:25 pm
I tested with water. It at least gave me a base line. There were a few months between doing my fuel system and flying the plane, so drying out was not an issue. My plane was in the basement, so I did not want to test with fuel. I did another check with just a couple of gallons of fuel once I had the plane at the airport.
Re: Leak check
Postby Bryan Cotton » Sun May 17, 2015 8:40 pm
Thanks for the thoughts guys. Steve, I did just as you described on the 140- balloon and soapy water. Still due to the flow restriction to the balloon it swelled the tank a bit. Scarier in a 65 year old aluminum tank that is made by welding top to bottom as compared to our plastic tanks.
Re: Leak check
Postby Gripdana » Sun May 17, 2015 10:53 pm
If you test with water do not do it with the Princeton fuel probe installed. The probe does not like water even if you wait a year to let it dry out. The first probe I had was destroyed by water when I tested for leaks. The newer directions tell you to "dry" out the probe with low heat. Mine was completely corroded.
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Users browsing this forum: Bing [Bot] and 43 guests
