by WaiexN143NM » Wed May 13, 2015 12:54 am
Hi doron,
A few other hints to the dynon set up, u need to run a autopilot disconnect switch mounted somewhere handy, u need to use this switch in the set up and calibrate mode. I used db-9 connectors for the wiring, but u only need to run a few wires to run the servos. You can also gang the wires for the servos, meaning I made a "Y" cable to the 2 servos, and you can do this for the power wires too. A good source for electrical stuff : B and C Specialty products , Newton KS. Mr Bill bainbridge. Peruse his website , a good book u can order from him from Bob Knuckols 'The aero electric' takes all the guess work out of aircraft wiring. Again don't be alarmed if your autopilot doesn't function well on the ground. Plane needs to be moving for GPS position and especially the adhrs sensing. The pitch servo went to full down and clutch slipping. I believe from the TD on the ground attitude. We mounted our adhrs in the bay behind the baggage bay. Let us know how it goes, good luck!!
Waiex N143nm
Michael RADTKE
