SonexN76ET wrote:Secondly, I need to state that it is wrong and just plain dangerous advice some have given on using reducers simply screwed into the plastic tank instead of using the oops fittings. The reducers will not work by just screwing them into the plastic. They will work out from vibration and side loads on the lines and fittings attached to them. The only way to make the reducers work long term would be to put washers on both sides of the tank with O rings under the washers and a nut on the inside of the tank. I tried screwing in a reducer without washers, O rings, and nuts and wiggled the reducer and it loosened up pretty quickly. You have to have compression with an o ring on either a reducer or oops fitting in order for it to seal long term. I don't know how you could apply torque to a nut inside of the tank on a reducer, so I believe the oops fitting is the superior method.
Return to Technical Write-Ups and FAQs
