Motor mount shims
Re: Motor mount shims
Postby 142YX » Sun Dec 04, 2011 3:26 am
I ended up attaching my engine mount today.. and i used .090" shims on all four corners. Fit like a glove with that thickness, and just for reference, i did nail that 32" dimension dead on.
450 hours and counting..
142YX
Postby N111YX » Sun Dec 04, 2011 11:31 am
That looks really good! It's fun to see all of the updates...!
I'm seeing lot's of progress being made in the colder months... :D
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby 142YX » Sun Dec 04, 2011 3:47 pm
While i am on the subject.. what are people using to corrosion protect the exposed 4130 steel when you drill through that nice powder coating? I was thinking of just touching it with some automotive engine (high temp) stuff from a rattle can.. i also thought about epoxy primer but am favoring a simpler/cheaper method as i dont quite think that will be necessary.
142YX
Postby Andy Walker » Mon Dec 05, 2011 4:36 pm
142YX wrote:I ended up attaching my engine mount today.. and i used .090" shims on all four corners. Fit like a glove with that thickness, and just for reference, i did nail that 32" dimension dead on.
Thanks for the pics...based on the gaps I'm seeing now, my shims will be similarly sized.
Andy Walker
Postby N111YX » Tue Dec 06, 2011 9:48 pm
You're in the desert. I would not sweat it... :lol:
I would imagine that touch up paint would be adequate. I'll bet that our airframes will all last longer than all of us and the next guy or the guy after that will have to worry about all corrosion...
142YX wrote:While i am on the subject.. what are people using to corrosion protect the exposed 4130 steel when you drill through that nice powder coating? I was thinking of just touching it with some automotive engine (high temp) stuff from a rattle can.. i also thought about epoxy primer but am favoring a simpler/cheaper method as i dont quite think that will be necessary.
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby Andy Walker » Tue Dec 06, 2011 11:13 pm
N111YX wrote:You're in the desert. I would not sweat it... :lol:
Sounds about right. I used NAPA 7220 self-etching primer on my elevator horn, seemed to work well.
Andy Walker
Postby 142YX » Wed Dec 07, 2011 1:43 am
Yea i don't sweat it on the aluminum at all.. but the steel makes me nervous. What i think i am going with is some Rustolium rattle can high temp engine block paint.. Home Depot's finest. Should be enough to prevent rust.
142YX
Postby 142YX » Wed Dec 07, 2011 2:18 am
Andy Walker wrote:Sounds about right. I used NAPA 7220 self-etching primer on my elevator horn, seemed to work well.
Careful.. you will probably need to apply a "sealer" to that primer for it to provide any corrosion protection. The primer alone dosen't provide much of anything other than a good surface for a sealer or top cote to bond to.
This is off topic for this tread, but i did the whole corrosion protection flip flop for several months and eventually decided not to do anything to the aluminum itself. I strongly believe i will still have a 50 year airframe.
142YX
Postby fastj22 » Wed Dec 07, 2011 9:26 am
I owned a 1966 Cessna 150. Zero corrosion in 2011.
Postby Andy Walker » Wed Dec 07, 2011 12:05 pm
I'm with you on the aluminum, not doing anything to it. On the steel I really just wanted something to cover the bare steel. Between the bare primer and the fasteners in the holes I'm confident it will survive with the small amount of water it will be exposed to (plane will be in a hangar). If there is a problem with steel corroding you will see long before it's a structural issue if you are even half awake during pre-flights and condition inspections.
Andy Walker
Users browsing this forum: No registered users and 44 guests
