H All,
Just an update on my painting experiences.
I’ve mow completely abandoned the roll on method. The paint I’m using just does not seem to work that well rolling it on.
I’m just spraying it on and getting much better results.
I’m still using the same Norglass paint though and I am very happy with it.
The primer is a 2K epoxy, the paint is a 2K polyurethane.
Spraying was a bit of a struggle at first but I’m getting the hang of it.
The primer is easy, no problem with that at all, but the top coat is a bit more tricky.
Apart from getting the consistency of the paint correct, I find it’s all about getting the balance right between having enough paint on there so it flows out right, but not too much so it doesn’t start sagging and/or running.
Initially I had a few parts I had to sand down and start over but luckily my technique has improved a lot since.
Anyway, you can see some pictures below. So far I’ve done the elevator, flaps, ailerons, vertical and horizontal stabilizer.
Now I have to move on to the bigger bits, starting with the wings this week.
Oh yeah, instead of etching/alodyning to prepare the aluminium, I’m using a product called “PreKote” (
http://www.prekote.com/).
For those who are not familiar with PreKote, It’s an aviation grade product that replaces these processes but is much more environmentally friendly. I highly recommend it.
