kmacht wrote:So I am running into an interesting problem that must be common to all Sonex. Communications when flying or landing are fine but when taking off the noise from the engine and fusealage is making it hard for people to hear me on the radio over all the noise. Is there some sort of adaptor that can be used with the headset to help reduce the noise? Are there headsets that work better than others for this problem? I know it isn't just my plane as we had the same issue with the Sonex owned plane when doing transition training. Until you pull the power back on the downwind leg your voice gets lost in the all the noise coming through the microphone. Someone must have a solution.
#554
kmacht wrote:I admit that I have a cheap radio setup. It is an icoms a6 run through a sp-200 intercom and am using a stock David Clark 13.4 headset. I would chalk it up to the radio except we had the same issue in the factory trainer and that had a panel mount radio in it. It isn't electrical noise that is the problem. It is the ambient noise on climbout. The radio sounds fine when in the pattern or flying anywhere other than climbout. I thought that maybe there was a solution out there already from the ultralight crowd as I imagine they have the same issue.
#554
Users browsing this forum: Bing [Bot] and 44 guests
