WALTWESTER wrote:Any one using a Bing Carb on their 3300? If so, what combination of main and needle jets have worked out for you?
Thanks Waltwester@earthlink.net
pgerhardt wrote:I have a 3300 with the Bing. The first 90 hrs or so were with the stock economy jets that came with the engine. Last year I leaned it up some by changing both the main and needle jets. I did this twice but can't remember what size is in now. It is still a bit rich and want to try a Hacman this year. I did put in all six thermocouples for both EGT and CHT. My main issue it seems it that the EGT are uneven front to back.
1&2 1320 or so
3&4 1100 or so
5&6 950 or so
nice and even right and left and CHT are 'OK' with #3 running the warmest.
Filter is on carb air intake in the cowl.
225 hrs and it runs well but would love to have it more even and a bit leaner in cruise.
Paul
N148YX
Corby202 wrote:Hi Steve
Could you please elaborate on this. Naca duct, Jabiru supplied?? How do you connect the Naca duct to the heat box, Jabiru supplied?? and then to the Carbi if you are not using scat tube.
Phil
pgerhardt wrote:David
I have read all the discussions and but have not yet tried removing the airfoil. Will do that next month.
I also bought an X vane but not sure that will do anything. Will try one at a time...
Paul
