Tail Wheel Spring Bent?
Postby pgerhardt » Tue Apr 21, 2015 5:30 pm
I have a Waiex tail wheel spring that has bent slightly over the last 200 hrs and many landings. The "Kip" tailwheel assembly is starting to scrape the ground a bit over bumps.
Question - is it possible to remove the bolt and rotate the spring 180 degrees?
Can you get to the bolt through the top or the bottom?
Inspection is coming so all the panels will come off soon. The other option is to bend it back to shape. Is the steel holder strong enough?
I have put a small wire spool under it and stood on the spring. It may be possible but I don't want to hurt anything.
I probably have about 400 landings on it and some have not been "greased on"!
Paul
N148YX
pgerhardt
Re: Tail Wheel Spring Bent?
Postby radfordc » Tue Apr 21, 2015 5:51 pm
I bent my tailwheel spring during a rough landing. I couldn't just rotate it 180 since the hole had been drilled off center. I removed the spring rod and had it straightened in a hydraulic press. The guy who did it actually overbent it just slightly and it stayed straight after that.
radfordc
Postby Bryan Cotton » Tue Apr 21, 2015 5:53 pm
Paul,
If you have drilled the holes perfectly centered and perpendicular to each other then you should be able to flip the spring. Mine - no way!
Postby tonyr » Tue Apr 21, 2015 6:17 pm
The emerging problem in my tailspring is the fuse end hole is starting to wallow and I can rotate the rod/tailwheel assembly slightly. I think I might shim the hole with some .005" stainless shim stock. I used same to remove the slop between the spring rod and the tubes it slots into.
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Postby pgerhardt » Tue Apr 21, 2015 6:59 pm
I am not the builder so have no idea of the precision of the drilling. I do have access to a hydraulic press so will plan on that and see if I "luck out" and get the bolt in "the other way". Something to do during inspection that I have to get an A&P to do. My fuse end hole seems to be tight. I do not notice any movement when moving the plan in and out by the tailwheel.
pgerhardt
Postby Bryan Cotton » Tue Apr 21, 2015 7:08 pm
I shimmed mine with epoxy.
Postby fastj22 » Tue Apr 21, 2015 7:34 pm
pgerhardt wrote:I am not the builder so have no idea of the precision of the drilling. I do have access to a hydraulic press so will plan on that and see if I "luck out" and get the bolt in "the other way". Something to do during inspection that I have to get an A&P to do. My fuse end hole seems to be tight. I do not notice any movement when moving the plan in and out by the tailwheel.
You could possibly flip the rod end for end, rotate 90 degrees and re-drill both holes. I doubt just rotating it 180 will align it.
Postby mike.smith » Tue Apr 21, 2015 8:43 pm
I know of one Sonex owner who bent his main gear leg and bent it back with a press. Been going strong for many many landings since. Both are made of titanium.
Postby kevin814 » Tue Apr 21, 2015 9:44 pm
Those titanium gear legs are a great. Very tough and good fatigue resistance. If it gets bent, you can bend it back and it doesn't seem to matter. Sonex could have saved some money by using a lesser material, but that is one feature that helped to sell me on the brand.
Kevin K.
Cincinnati
kevin814
Postby DCASonex » Wed Apr 22, 2015 8:28 am
Bent mine couple of years ago. Got okay from Sonex to straighten it and did so by simply clamping one end in large bench vise and slipping length of pipe over the other end and yanking it back to straight. Been fine since.
Also for those asking about do-it-your-self 6" tail wheel, used a Colsun Performa round tread caster wheel # 5.00006.5PS that only cost about $15. This is a plastic hub wheel that happens to come standard with two sealed precision ball bearings, better bearings than in many pricey wheels sold as "tail wheels" . Tread is polyurethane. It has stood up well over time, 185 hours, and survived that spring bending incident without damage. Bracket was made from one piece of 0.100 thick 4130 steel folded to shape with only minor welding along edges where folded back on itself. Drawings of wheel and bracket on request.
Users browsing this forum: No registered users and 87 guests
